Announcements
Extract ground points section to model or file like land does.
e_omairquliey
e_omairquliey
Hallo guys i have problem that i can't extract the ground points section from civil 3d , i have searched the report section a lot of times and i couldn't extract them to model or file like land help me...
Accepted solutions (3)
Replies (25)
Jeff_M
You will need to be a little more specific. "Like Land" doesn't help much since I haven't used LDT in 14+ years. Are you wanting the EG along a profile or a section at specific stations, or ???? A sample of what you need would be helpful.
Jeff_M, also a frequent Swamper
e_omairquliey
TerryDotson
If you were to consider third party add-ons, DotSoft's C3DTools will process an alignment, collecting points (optionally places CogoPoints) along the sample lines.  Exports station, offset, northing, easting and surface elevation at specified intervals (like -10,0,10) or all points where the sample line intersects the triangles of the surface.
e_omairquliey
That mean i need to download that tool to get the points.
hosneyalaa
Hi @e_omairquliey
Can you attached example drawing In which what You want
e_omairquliey
welcome Hosneyalaa
Do you know how to use land desktop?
e_omairquliey
Do you know how to use land desktop, if yes i will give you the order that make the ground section sample so you can know what i need exactly.
hosneyalaa
I was Use it a long time ago
no I remember What's your order
e_omairquliey
this is the order in land desktop to import the ground points section to model.
hosneyalaa
Ok ...
whats the result using this command Surely ...
there is something like it in civil 3d program But you need to export it to Excel then import pervaded
e_omairquliey
that's great. so learn me how to import them to Exel from civil 3d.
hosneyalaa
e_omairquliey
hosneyalaa
e_omairquliey
Okay. i will send you an civil3d file.dwg there is a project inside it. i need to extract the ground points which view in sample sections every 25 meters.
the project is ready to plot but the problem in how i could extract the points ground section like land.
e_omairquliey
Okay. i will send you an civil3d  dwg file there is a project inside it. i need to extract the ground points which view in sample sections every 25 meters.
e_omairquliey
He didn't extract the original ground point data to excel or model and didn't rap about this subject.
we are in Yemen attached with any design the ground points table for every station and those points most apply with the ground elevation and offset with appear in station section plot.
hosneyalaa
try
