In the lower right corner of Civil 3D is a three bar icon that is for “Customization”
When open you can turn on/off the display of items like Coordinates, Units, Transparency.
Is there a way to turn these on/off in a lisp file?
I am aware of
setvar "COORDS" 1
This however does not turn on the display of the coordinates at the bottom just sets the value displayed or not.
I don't know how to do this using a lisp, but you can set this up under the Registry Editor:
HKEY_CURRENT_USER\SOFTWARE\Autodesk\AutoCAD\R21.0\ACAD-0000:409\Profiles\<<C3D_Imperial>>\StatusBar\Application
All of them need to be set as 1 in order for them to show on the Status Bar.
Hope that helps
Tatiana Machado
BIM Manager/ Autodesk Certified Instructor
Blog | Twitter | LinkedIn
InfraWorks Ambassador
Toggling the values off/on didn't seem to have any effect on the StatusBar Coordinate display.
(vl-load-com) (defun CoorToggle ( / key ) (setq key (strcat "HKEY_CURRENT_USER\\" (vlax-user-product-key) "\\Profiles\\" (getvar "cprofile") "\\StatusBar\\Application")) (if (= (vl-registry-read key "CursorCoordinatesPane") 1) (vl-registry-write key "CursorCoordinatesPane" 0) (vl-registry-write key "CursorCoordinatesPane" 1) ) )
There may be no lisp solution.
