Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
“Customization” turn on off items like Coordinates, Transparency with lisp file.
2 REPLIES 2
544 Views, 2 Replies
In the lower right corner of Civil 3D is a three bar icon that is for “Customization”
When open you can turn on/off the display of items like Coordinates, Units, Transparency.
Is there a way to turn these on/off in a lisp file?
I am aware of
setvar "COORDS" 1
This however does not turn on the display of the coordinates at the bottom just sets the value displayed or not.
2 REPLIES 2
tmachado
I don't know how to do this using a lisp, but you can set this up under the Registry Editor:
HKEY_CURRENT_USER\SOFTWARE\Autodesk\AutoCAD\R21.0\ACAD-0000:409\Profiles\<<C3D_Imperial>>\StatusBar\Application
All of them need to be set as 1 in order for them to show on the Status Bar.
Hope that helps
Hope this will help!
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the LIKES button
Tatiana Machado
BIM Manager/ Autodesk Certified Instructor
Blog | Twitter | LinkedIn
InfraWorks Ambassador
TomBeauford
in reply to: tmachado
Toggling the values off/on didn't seem to have any effect on the StatusBar Coordinate display.
(vl-load-com)
(defun CoorToggle ( / key )
	(setq key (strcat "HKEY_CURRENT_USER\\" (vlax-user-product-key) "\\Profiles\\" (getvar "cprofile") "\\StatusBar\\Application"))
	(if (= (vl-registry-read key "CursorCoordinatesPane") 1)
		(vl-registry-write key "CursorCoordinatesPane" 0)
		(vl-registry-write key "CursorCoordinatesPane" 1)
There may be no lisp solution.
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
Rail Community
