Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Command to rotate General Note Label
20 REPLIES 20
Message 1 of 21
htls69
1456 Views, 20 Replies
Trying to create a lsp command that will rotate a general note label
we have one that rotates Points ie z1, z2, z3, z4 That rotates the point to the respective quadrant
That lisp is below
;;; point rotation quadrant 1
(defun c:Z1 (/ doc pt sourcept ss ss2)
(setq rlang (- (* pi 0.25) (getvar "viewtwist")))
  (vl-load-com)
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (vla-startundomark doc)
    (princ "\n....select Points to change: ")
    (if (setq ss (ssget '((0 . "AECC_COGO_POINT"))))
	(while (> (sslength ss) 0)
	  (setq pt (vlax-ename->vla-object (ssname ss 0)))
	  (vlax-put pt 'labelrotation rlang)
	  (ssdel (ssname ss 0) ss)
  (vla-endundomark doc)
  (princ)
If someone could help me that would be awesome.
I would like to have 4 lsp routines Like-- L1, L2, ,L3, L4
Allen Robberson
Credit where credit is due! Give kudos or accept as solution whenever you can.
20 REPLIES 20
Message 2 of 21
Jeff_M
in reply to: htls69
Unfortunately the Rotation property is not exposed for the Note Label in the COM API. This can be done using .NET, however. Attached is a zip file with a small .NET dll. Be sure to Unblock the zip file after downloading by locating the file in File Explorer, rt. click, properties, General tab, Unblock near the bottom of the dialog. You can create as many small lisps to call it with whatever rotation angle you wish. Here the one for 45 degrees:
(defun c:N1 (/ rlang )
   (NoteLabelRotate rlang)
   (princ)
Add a line similar to this to your acad.lsp file so the NoteLabelRotate lisp function will always be available:
(netload "c:\\LocationOfMyCustomFiles\\RotateNoteLabels.dll")
Jeff_M, also a frequent Swamper
Message 3 of 21
htls69
in reply to: Jeff_M
I added it like this
(defun S::Startup ()
(princ "Changing VARIABLES...")
(setvar "FILEDIA" 1)
(setvar "SAVETIME" 5)
(setvar "SAVEFIDELITY" 1)
(setvar "PEDITACCEPT" 1)
(setvar "MAXSORT" 8000)
(setvar "OSNAPZ" 1)
(setvar "FACETRES" 10)
(setvar "ISOLINES" 2047)
(setvar "PDMODE" 2)
(netload "T:\ACTION\RotateNoteLabels.dll")
(command "VIEWRES" "Y" 20000)
(command "UCSICON" "ON")
(command "AUDITCTL" "0")
(command "_-PLOTSTAMP" "_LOG" "_NO" "PLOT.LOG" "")
 but i am getting this when it loads
Command: Changing VARIABLES...Regenerating model.
; error: no function definition: NETLOAD
Command:
Allen Robberson
Message 4 of 21
htls69
in reply to: Jeff_M
ok i tried changing the angle but it does not change the rotation
   (princ)
Command: N1
Select NoteLabels to rotate -343°-23'-15" degrees: 1 found
   (setq rlang (- (* pi 0.50) (getvar "viewtwist")))
   (princ)
Command: (LOAD "T:/ACTION/n1.lsp") C:N1
Command: n1
Select NoteLabels to rotate -253°-23'-15" degrees: 1 found
but label stays at 000°00'00"
Allen Robberson
Message 5 of 21
Jeff_M
in reply to: htls69
Sorry about the wrong directions for adding to the acad.lsp file. Netload is a command, so needs to be used like this:
(command ".Netload" "pathtothefile\\filename.dll")
As for not changing the rotation, it's working as expected here.
I just found where it doesn't work...when this:
returns a negative value, the API uses 0. Attached is a lightly modified version that ensures the value is positive which appears to work for all cases.
Message 6 of 21
htls69
in reply to: Jeff_M
It is not loading when the drawing starts. Had to load it myself with netload.
.Netload Assembly file name: T:ACTIONRotateNoteLabels.dll Unable to load T:ACTIONRotateNoteLabels.dll assembly.
Command: N1
; error: no function definition: NOTELABELROTATE
Command:
Command: N1 ; error: no function definition: NOTELABELROTATE
Command:
Command: NETLOAD
Command: N1
Select NoteLabels to rotate -118°-23'-15" degrees: 1 found
Command:
Command:
Command: N1
Select NoteLabels to rotate -163°-23'-15" degrees: 1 found
Command:
Command:
The angle is still not changing
Allen Robberson
Message 7 of 21
htls69
in reply to: htls69
file i am using
Allen Robberson
Message 8 of 21
htls69
in reply to: htls69
I got it to autoload with registry
Allen Robberson
Message 9 of 21
Jeff_M
in reply to: htls69
OK, good. The attached version should work for you. Tested in your drawing and it worked on all of the Note Labels I selected.
Message 10 of 21
htls69
in reply to: Jeff_M
ok now i just need a little help with the lsp
n4    |    n1
n3    |    n2
need to rotate labels to quadrant angles n1=    45 degrees of the current view
        n2= 135 degrees of the current view
        n3= 225 degrees of the current view
        n4= 315 degrees of the current view
   (setq rlang (- (* pi 0.0) (getvar "viewtwist")))
   (princ)
(defun c:N2 (/ rlang )
   (setq rlang (- (* pi -0.25) (getvar "viewtwist")))
   (princ)
(defun c:N3 (/ rlang )
   (setq rlang (- (* pi -0.75) (getvar "viewtwist")))
   (princ)
(defun c:N4 (/ rlang )
   (setq rlang (- (* pi -1.25) (getvar "viewtwist")))
   (princ)
Thanks for all your help on this.
Allen Robberson
Message 11 of 21
Jeff_M
in reply to: htls69
This works for me:
   (princ)
   (setq rlang (- (* pi 0.75) (getvar "viewtwist")))
   (princ)
   (setq rlang (- (* pi 1.25) (getvar "viewtwist")))
   (princ)
   (setq rlang (- (* pi 1.75) (getvar "viewtwist")))
   (princ)
Message 12 of 21
Jeff_M
in reply to: Jeff_M
I didn't look at your diagram, Allen. So the lisps don't match what you were looking for. Just change the defuns to match....so my N4 should be N2 and N2 should be N4
Message 13 of 21
htls69
in reply to: Jeff_M
they need to be at 45 to the current view in the drawing and they are direct up-right-down-left
n1=ne
n2=se
n3=sw
n4-nw
Allen Robberson
Message 14 of 21
Jeff_M
in reply to: htls69
Using your drawing and the lisps I posted they do exactly that...45 degrees to the current view.
Message 15 of 21
htls69
in reply to: Jeff_M
See screencast below
https://autode.sk/39pz9Wh
Allen Robberson
Message 16 of 21
Jeff_M
in reply to: htls69
You are selecting NoteLabels whose contents are set to be at 45 degrees, so rotating the label 45 degrees makes it 90 degrees....
Try it with one of the General Text notes, such as the Lawn labels, and you will see it works as expected.
Message 17 of 21
Jeff_M
in reply to: Jeff_M
If you want those labels with the set rotation of 45 degrees to always show at 45 to the view, change the LabelStyle Orientation Reference property to View instead of World Coordinate System.
Message 18 of 21
htls69
in reply to: Jeff_M
I don't want it to rotate the current label i want it to set a fixed angle  based on the current view.
like this one does for points
  (vl-load-com)
  (princ)
Allen Robberson
Message 19 of 21
Jeff_M
in reply to: htls69
Allen, it is doing exactly that. Try the Point lisp Z1 on a Point whose label style's text contents are rotated 45 degrees. You will see the same thing you do with the tool I provided for the Notes.
See message 16 above.
Message 20 of 21
Jeff_M
in reply to: Jeff_M
You can get this to work with NoteLabels having the 45 degrees already set in the style by creating new calling lisps at 90 degree increments:
(defun c:N1R (/ rlang )
   (princ)
(defun c:N4R (/ rlang )
   (setq rlang (- (* pi 0.5) (getvar "viewtwist")))
   (princ)
(defun c:N3R (/ rlang )
   (setq rlang (- (* pi 1.0) (getvar "viewtwist")))
   (princ)
(defun c:N2R (/ rlang )
   (setq rlang (- (* pi 1.5) (getvar "viewtwist")))
   (princ)
Rail Community
