Will the Autodesk® LiNZ Survey Utility be available for C3d 2020?
If yes where could I found it?
Solved by Civil3DReminders_com. Go to Solution.
I'd suggest making a support case to Autodesk directly at Manage.Autodesk.com or https://knowledge.autodesk.com/contact-support/using-my-product or contact your reseller. Autodesk doesn't always monitor the forums and asking directly might be best.
