Tunnel Section View & VBA
OceanaPolynom
OceanaPolynom
Hello
I used C3D to make section views of a cross passage between two tunnels.  Typically  they look like this:
Now I need to calculate the distance between the circles on the corridor section and the nearest point on the section line that represents the surfaces.  One way might be to explode the section objects back to simple acad entities.  My question is, is there any way to directly access the C3D section objects to accomplish the same task?
Thank you
John
hippe013
Are you able to post an example drawing?
OceanaPolynom
Hello
I have attached 2 example files.  There is a different assembly in each file.
Thank you
John
