XSL REPORT EDITING (Adding distance column)
EREEEE
EREEEE
Hi I want to add DISTANCE COLUMN my volume reports.
Can anybody help my?
Civil3DReminders_com
You'll want to change the xsl style sheet:
C:\ProgramData\Autodesk\C3D 2017\enu\Data\Quantities Report Style Sheets\xsl\Select Material.xsl
Adding the column is easy, just follow the existing pattern:
Then down below you'll want to add a <td> </td> cell for the distance.
You'll then want to take the previous station value with the current station. I'm not good enough to quickly do this, so you'll have to come up with it.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
EREEEE
thanks for solution, but i am not good enough like you 🙂
I hope someone see my post, better than us.
