Evaluate the next type of entity - Visual Basic .NET
Message 1 of 8
I need to generate a code that evaluates if the current entity is a line and if the next entity is also a line. I'm using the following code, but I can not get the result I want.
Please, excuse my mistakes. I'm learning.
For i As Integer = 0 To align1.Entities.Count - 1
Dim enti As AlignmentEntity = align1.Entities.GetEntityByOrder(i)
If (enti.EntityType = AlignmentEntityType.Line) Then
Dim nextenti As Integer = enti.EntityAfter
Dim nextentity As AlignmentEntity = align1.Entities.Item(nextenti)
If (nextentity.EntityType = AlignmentEntityType.Line) Then
pipqce(i) = 1
pipqcn(i) = 1
Continue For
Next i
Can someone help me with an example .net code.
Thank you very much.
Best regards.
Mauro Vega
AutoCAD Civil 3D 2018.1
Intel Core i7-6700HQ CPU 2.6 GHZ
32 GB RAM 2133 MHz
NVIDIA Quadro M3000M
Windows 10 Pro 64 Bits
Replies (7)
Message 2 of 8
TiStars
for getting next Entity, I will use
Dim nextentity As AlignmentEntity = align1.Entities.GetEntityByOrder(i+1)
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
您的问题是否已得到解答?请点击“接受解答”按钮。
Message 3 of 8
TiStars
I tried in C# with this:
AlignmentEntity aliEntiNext = align1.Entities.EntityAtId(aliEnti.EntityAfter);
I don't know if "align1.Entities.Item(nextenti)" works or not, but in C#, I can get Entity by align1.Entities.EntityAtId() Method. And then I can get EntityType of it.
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
Message 4 of 8
TiStars
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
Message 5 of 8
Hello TiStars,
Thanks for your help.
When using this code
The following error occurs:
The exception occurred Autodesk.Civil.EntityNotFoundException.
HResult=0x80131500
Message = NoNextAlignmentEntity,
I do not know what may be happening.
Best regards.
Mauro Vega
32 GB RAM 2133 MHz
Message 6 of 8
TiStars
Hi mvege,
Does the next Entity exist? or the error occurs from the beginning?
when i = align1.Entities.Count -1, there will be no more Entity behind the current one.
so I am afraid this
will have to be changed to
For i As Integer = 0 To align1.Entities.Count - 2
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
Message 7 of 8
Hello TiStars,
Best regards.
Mauro Vega
32 GB RAM 2133 MHz
Message 8 of 8
TiStars
My pleasure Mauro.
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
