- Mute
- Permalink
- Report
I have created Property Set data to add my files as metadata as below
As I progress my design I type SAVE on the command line and append the name with _SuitabilityCode_RevisionCode as shown below. The "live" drawing will always end with a 4 digit number so as per screenshot my current file will next be SAVEd as P01.04 and I manually increment the Revision on my 0001 drawing to P01.05.
I would like to automate this such that the Suitability code and Revision get added as part of the SAVE but I have no idea if this is possible or indeed how to achieve it. I have done a similar thing for Excel files via VBA which works fairly well but AutoCAD programming is a mysterious art...!!!!
Can anyone advise and hopefully post up some code to do this?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
