Hi all,
I am hoping someone can help me with this. I am trying to allow for the selection of multiple cogo point but also filter so only cogo points can be selected. I have been playing with the code below but it does not show my custom message; it seems to bypass it completely. I am sure it is something simple but I just cant get it. Any help would be greatly appreciated.
Try 'Create a typedvalue array to define the filter criteria Dim acTypValAr(0) As TypedValue acTypValAr.SetValue(New TypedValue(DxfCode.Start, "AECC_COGO_POINT"), 0) 'Assign the filter criteria to a selectionfilter object Dim acSelFtr As SelectionFilter = New SelectionFilter(acTypValAr) Dim promptSelectionOptions = New PromptSelectionOptions promptSelectionOptions.MessageForAdding = (vbLf & "Select COGO Points to move labels:") Dim selectedCogoPointsResult = SelectionPromptResults(acSelFtr) 'If selection is a cogo point If selectedCogoPointsResult.Status = PromptStatus.OK Then Dim acSSet As SelectionSet = selectedCogoPointsResult.Value
In conjunction with this function:
Private Function SelectionPromptResults(options As SelectionFilter) As PromptSelectionResult Dim acDocEd As Editor = Active.Editor Return acDocEd.GetSelection(options) End Function
