Programatically creating multiple surfaces
The Problem
We programmatically create surfaces in Civil 3D 2014. The problem is they are residing on layer 0. When importing into 3DS Max, all the surfaces TINs are on layer 0, which we want them to reside on the assigned layer.Also, I am using cut and pate surfaces programatically. The initial surface is on layer 0 (Standard Style).
Here is the example of the 3DSMax file where the TIN is on layer 0. The goal is to have each TIN on the assigned layer.
A few more details.
The Overall surface is Layer 0 (Standard Style)--(Named "All")
Our custom pasted surfaces all have assigned layers for the objects
The Goal
I am trying to figure out the workflow that is causing the layers(TIN objects specifically) not to import on the assigned layer.
Files
2 3DSMax file and 1 Civil 3D 2014 file.
Any Ideas?
Jeff_M
If you are importing the All surface into 3dSMAX then the TIN will be on layer 0. Importing of each of the surfaces individually should place them on their own layers. I don't have 3DS to look at that file.
After searching the import methodology into 3DSMax, I am not able to use the extract objects from Civil for performance reasons. So, I need to tackle the layer 0 situation on the Civil side. If you create a surface manually, there is a setting for the object's base layer to be set on creation. I do not know if this property is exposed in the API. This should solve the problem, if there is access.
Jeff_M
Surfaces do inherit the Layer property from the Entity object, so the layer can be set to whatever you need by specifying the Layer Name.
surf.Layer = "C-Surf-Layer"
Perfect! I had to backup a bit. I searched the object browser for under TINSurfaces and the layer setter was not readily visible, and to muddy things up a bit, there was a custom surface class that I actually searched the wrong object tree. Thanks! LOL
