- Mute
- Permalink
- Report
The Problem
We programmatically create surfaces in Civil 3D 2014. The problem is they are residing on layer 0. When importing into 3DS Max, all the surfaces TINs are on layer 0, which we want them to reside on the assigned layer.Also, I am using cut and pate surfaces programatically. The initial surface is on layer 0 (Standard Style).
Here is the example of the 3DSMax file where the TIN is on layer 0. The goal is to have each TIN on the assigned layer.
A few more details.
The Overall surface is Layer 0 (Standard Style)--(Named "All")
Our custom pasted surfaces all have assigned layers for the objects
The Goal
I am trying to figure out the workflow that is causing the layers(TIN objects specifically) not to import on the assigned layer.
Files
2 3DSMax file and 1 Civil 3D 2014 file.
Any Ideas?
