ProfileView Pipe & Structure Overrides problem
Jeff_M
Consultant Consultant
Jeff_M
Just ran into a new issue with the Overrides for Pipes and Structures. This does not seem to be related to the previous issue where parts lying on the alignment are not included.
I have a short profile view which has storm and sanitary parts displayed. There are 2 structures and 1 pipe for each network. The profileview properties correctly show this. However, accessing the StructureOverrides of the PV object only returns 2 structures, 1 from each network. The PipeOverrides correctly returns 2 pipes.
hosneyalaa
hi @Jeff_M
my language is not good
I don't understand much about you
can i try this thanks
attached .dyn file
