Pressure Network Part Swapping
smurrin
smurrin
I would like to see Pressure Networks have the same capability as Gravity Networks with the swapping of pipes and structuers. When changes come and we need to increase or decrease the size of out networks it would be awesome to be able to just swap the pipe and fittings/appurtances likewe do with gravity netwoks. Please add this ability. ThanksSmiley Happy
peterfunkautodesk
We are looking into part swapping of pressure networks. This is a pretty popular topic on Idea Station.
Cheers
Peter Funk
Autodesk, Inc.
smurrin
OK that is good to know......i can't wait Smiley Happy
rjairath
any updates on pressure pipe parts swapping?
it is such a key component to working with design software.
Thank you for reading,
Win7 64bit Pro
Xeon E5-1620 v2, 3.70GHz, 32GB Ram
Please mark solution found if this post solved your issue or give kudos when appropriate.
smurrin
Haven't heard of anything yet. They do need to jump on this. swapping parts seems like it should have been put in from the beginning....AUTODESK GET ON THIS
MehtaRajesh
Any Update from Autodesk regarding this Swap part for Pressure Network?
Rajesh
smurrin
Yea it looks like Civil 2018 does the part swapping. I haven't messed with it that much but at least it is there. I was planning on using the pressure network next time I get a smaller project to test it out on.
