Points API in 2012?
Points API in 2012?
Points API in 2012?
We have just upgrade to Civil 3d 2012 from LDD 08.  I have to update my VBA items to vb.net.  I have been looking for samples on the Points API, but i see that it has not been released.  So i have to use the COM API.  Does anyone have any samples on importing points thru the COM API for .net or point me in a good direction?  I know i can download the VBA installer for 2012 but need to convert code over to .net.
Thanks in advance
Hi Bill,
Points are not yet available in .NET, however you can use the exiting Points COM API in VB.NET application using Interop. I have  code snippet on creating COGO point in Civil 3D 2012 using COM API in a VB.NET project, I can share with you if that helps.
That would be great. You can email to bill.salling@uei-houston.com
Next time you are in Houston I will by you lunch or something
Hi Bill,
Here is a VB.NET code snippet to create COGO points using COM API in Civil 3D (in a .NET application ) :
<code_begin>
Public Sub CreateCOGOPoint()
        '' This sample Demonstrates Creation of COGO Point Civil 3D 2012
        '' Created by Partha P. Sarkar - DevTech, Autodesk
        Dim ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
        Dim oAcadApp As Autodesk.AutoCAD.Interop.AcadApplication = Nothing
        Dim oAeccApp As Autodesk.AECC.Interop.UiLand.AeccApplication = Nothing
        Dim oAeccDoc As Autodesk.AECC.Interop.UiLand.AeccDocument = Nothing
        Dim oAeccDB As Autodesk.AECC.Interop.Land.AeccDatabase = Nothing
        Using trans As Transaction = HostApplicationServices.WorkingDatabase.TransactionManager.StartTransaction()
            Try
                If oAcadApp Is Nothing Then
                    oAcadApp = GetObject(, "AutoCAD.Application")
                End If
            Catch ex As Exception
                ed.WriteMessage(ex.Message)
            End Try
            Try
                oAeccApp = oAcadApp.GetInterfaceObject("AeccXUiLand.AeccApplication.9.0")
                oAeccDoc = oAeccApp.ActiveDocument
                oAeccDB = oAeccApp.ActiveDocument.Database
                Dim oPoint As Autodesk.AECC.Interop.Land.AeccPoint = Nothing
                Dim pointLocation As Point3d = Nothing
                Dim promptPtOp As PromptPointOptions = New PromptPointOptions(vbCrLf + "Select the Location to create the COGO Point : ")
                promptPtOp.LimitsChecked = True
                promptPtOp.AllowNone = False
                Dim promptPtRes As PromptPointResult = ed.GetPoint(promptPtOp)
                If promptPtRes.Status <> PromptStatus.OK Then
                    ed.WriteMessage("Exiting! Try Again !")
                   Exit Sub
                End If
                pointLocation = promptPtRes.Value
                Dim location(0 To 2) As Double
                location(0) = pointLocation.X
                location(1) = pointLocation.Y
                location(2) = pointLocation.Z
                oPoint = oAeccDoc.Points.Add(CType(location, Object))
                oPoint.RawDescription = "RAW1"
                oPoint.Name = "NAME1"
                oPoint.Number = 10
                trans.Commit()
                ed.WriteMessage("Error : ", ex.Message & vbCrLf)
            End Try
        End Using
    End Sub
<code_end>
You might find the following DevTVs / Training videos useful (http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=8007696 😞
DevTV : Introduction to AutoCAD Civil 3D .NET Programming NEW!
A self-paced video tutorial on introduction to AutoCAD Civil 3D .NET Programming.
View Online | Download
DevTV: Introduction to Civil 3D Programming
A self-paced video tutorial demonstrating how to get started developing with Civil 3D.
View online | Download
Video : AutoCAD Civil 3D 2012 Surface .NET API
A self-paced video tutorial demonstrating the new Surface objects and related function in AutoCAD 2012 .NET API.
Hope this helps,
