How to delete/remove ParcelSegmentElement
How can I remove ParcelSegmentElement?
I have oPar as AeccParcel and oSeg as AeccParcelSegment
Here is my idea.. but not success yet..
AeccParcelLoop loop = oPar.ParcelLoops[0];
List<AeccParcelSegmentElement> SegElem = new List<AeccParcelSegmentElement>();
foreach (AeccParcelSegmentElement segE in loop)
  SegElem.Add(segE); // Seem not good idea here.. because all segE in this list look the same
foreach (AeccParcelSegmentElement oSE in oSeg)
if (!SegElem.Contains(oSE))
***delete/remove oSE here //can't find info, how to delete/remove this segment element
Pls help.. Thanks.
-Wanlop-
Civil3DReminders
I'm pretty sure you'd have to get the entity that's creating the ParcelSegmentElement and modify it. The ParcelSegment should be a reflection of the objects that make up the parcel.
Christopher
Thanks for your replied.
How can I get entity of ParcelSegmentElement ?
From the attached picture, I could get both Parcel (use as base to verify) and the ParcelSegment (iterate all element to check if it apart of base Parcel or not)..
Pls suggest more..
Just delete/remove one of ParcelSegmentElement  (not ParcelSegment).. still can't find the way to do..
Guide me please..
augusto.goncalves
Have you tried AeccParcelSegment.Delete() method?
Hope this help.
Augusto Goncalves
Autodesk Developer Network
Augusto Goncalves
Twitter @augustomaia
Thanks for the reply, but sorry it doesn't help.
What I need to delete is AeccParcelSegmentElement, not AeccParcelSegment.
Pls suggest..
Anyone help please...
