- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all, couple issues with the Parcel Reports in Toolbox....I appreciate any help with this. -(edit: this is using Civil 3D 2011 on Windows 7 x64)-
I have edited the "GeneralLegalPhrasings.xml" file used for the parcel report "General_Legal_Description_for_Parcels".
Two issues: 1. it will not label a reverse curve properly....it shows them all as "compound curves". 2. A curve to curve is always shown as "NonTangent".
I've attached the .xml file (I only edited the imperial parcels - the second large group of <Metes>).
Quite simply, these two "types" below have the words "reverse curve" and tangent or non-tangent accordingly in the output phrase, but it only creates non-tangent compound reports.
Curve to TangentReverseCurve
Curve to NonTangentReverseCurve
I appreciate any and all help/ideas. Thanks.
This is the report from the parcel in the attached dwg file (notice the "curve to the left" -> "curve to the right" labelled as compound, and all non-tangent curve to curve):
From the POINT OF BEGINNING; Thence, North 90° 00' 00" West, 129.16 feet to a point for corner;
Thence, North 00° 00' 00" East, 100.00 feet to a point for corner, the beginning of a curve; tangent
Thence, 61.46 feet along the arc of a ____ curve to the right, having a radius of 39.13 feet, a central angle of 90° 00' 00", and a chord which bears North 45° 00' 00" East, 55.34 feet, to a point for corner, the beginning of a compound curve; non-tangent
Thence, 47.09 feet along the arc of a ____ curve to the left, having a radius of 29.98 feet, a central angle of 90° 00' 00", and a chord which bears North 45° 00' 00" East, 42.40 feet, to a point for corner, the beginning of a compound curve; non-tangent
Thence, 94.33 feet along the arc of a ____ curve to the right, having a radius of 30.03 feet, a central angle of 180° 00' 00", and a chord which bears North 90° 00' 00" East, 60.05 feet, to a point for corner;
Thence South 00° 00' 00" West, 169.11 feet to the POINT OF BEGINNING
and containing 0.483 acres of land.
