file compression --> C3D dwg file??
granite07
granite07
Is the civil 3D dwg file compressed? The write time to the dwg file seems slow - and I thought maybe they use file compression and that is the lag. Does anyone know?
Forest Peterson, [email protected]; build-sheet
Alfred.NESWADBA
yes, DWG-files are compressed (the current versions) and it makes no difference if they are saved by Civil3D or ACA or plain AutoCAD. If they would not be compressed they would be as large as the memory is consumed when the drawing was opend (of course: about, not exactly).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
