Manipulate offset profile parameters
serpetfree
serpetfree
I'm trying to manipulate offset profile parameters. But nothing happens.
I can read offset profile parameters, but I can't write or remove.
I have Civil 3D 2022.1.1 Update.
I'm not sure I'm using it right, I don't know what I'm doing wrong, I'm trying 3 different ways. Why doesn't any of them work?
Here is my code snippet VB .NET:
Dim docCol As Autodesk.AutoCAD.ApplicationServices.DocumentCollection = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager
        Dim db As Database = docCol.MdiActiveDocument.Database
        Dim tr As Transaction = db.TransactionManager.StartTransaction()
        Dim ln As Long
        Dim lnProf As Long
        Dim id As ObjectId
        Dim idProf As ObjectId
        ln = Convert.ToInt32(alignmentHANDLE, 16)
        lnProf = Convert.ToInt32(profileHANDLE, 16)
        Dim hn As New Handle(ln)
        Dim hnProf As New Handle(lnProf)
            id = db.GetObjectId(False, hn, 0)
            Dim pl As Alignment = tr.GetObject(id, OpenMode.ForWrite) 'get offset alignmet
            idProf = db.GetObjectId(False, hnProf, 0)
            Dim plProf As Profile = tr.GetObject(idProf, OpenMode.ForWrite) 'get offset profile
            Dim staDouble As Double
            Dim slopeDouble As Double
            staDouble = 600
            slopeDouble = 0.05
            Dim Prof_Parameters As New Profile.OffsetProfileParameters(plProf)
            Dim Param_station As New Profile.OffsetProfileParametersStation(staDouble, slopeDouble, "test1")
            'method 1
            Prof_Parameters.Stations.Add(Param_station)
            'method 2
            Prof_Parameters.Stations.Insert(Prof_Parameters.Stations.Count, Param_station)
            'method 3
            staDouble = 700
            slopeDouble = 0.05
            Param_station.Station = staDouble
            Param_station.Slope = slopeDouble
            Param_station.Description = "test2"
            plProf.OffsetParameters.Stations.Add(Param_station)
            tr.Commit()
            tr.Dispose()
hosneyalaa
serpetfree
Thank you I have seen this page, but it's not working for me, I don't know.
plProf is Profile
Param_station is Profile.OffsetProfileParametersStation
But this is not working:
In my visual studio :
ReadOnly Property Profile.Offsetparameters As Profile.OffsetProfileParameters
I don't understand.
hosneyalaa
can you read this is
but it is Python Script node
https://forum.dynamobim.om/t/superelevation-to-offset-profile/65767/5
# Load the Python Standard and DesignScript Libraries
import sys
import clr
# Add Assemblies for AutoCAD and Civil3D
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AecBaseMgd')
clr.AddReference('AecPropDataMgd')
clr.AddReference('AeccDbMgd')
clr.AddReference('Civil3DNodes')
clr.AddReference('System')
from System.Collections.Generic import List
# Import references from AutoCAD
from Autodesk.AutoCAD.Runtime import *
from Autodesk.AutoCAD.ApplicationServices import *
from Autodesk.AutoCAD.EditorInput import *
from Autodesk.AutoCAD.DatabaseServices import *
from Autodesk.AutoCAD.Geometry import *
# Import references from Civil3D
from Autodesk.Civil.ApplicationServices import *
from Autodesk.Civil.DatabaseServices import *
# Import references for Dynamo for Civil 3D
from Autodesk.Civil.DynamoNodes import Alignment as DynAlignment
# The inputs to this node will be stored as a list in the IN variables.
dataEnteringNode = IN
adoc = Application.DocumentManager.MdiActiveDocument
editor = adoc.Editor
civdoc = CivilApplication.ActiveDocument
align = IN[0]
station = IN[1]
slope = IN[2]
result = []
oppsset = []
def offsetsuper(align,station,slope):
	global adoc
	global editor
	global civdoc
	try:
		with adoc.LockDocument():
			with adoc.Database as db:
				with db.TransactionManager.StartTransaction() as t:
					#Selected alignment ID and object
					alignment = align
					alignmentId = alignment.InternalObjectId
					al = t.GetObject(alignmentId, OpenMode.ForRead)
					alname = al.Name
					#Profile ID and object
					profileId = al.GetProfileIds()[0]
					profile = t.GetObject(profileId, OpenMode.ForWrite)
					profilename = profile.Name
					#get and clear existing parameters
					opp = profile.OffsetProfileParameters(profile)
					oppstations = opp.Stations
					oppstations.Clear()
					n = station.Count
					for i in range(0,n):
						slopepercent = slope[i]*0.01
						opps = profile.OffsetProfileParametersStation(station[i],slopepercent)
						oppsset.append(opps)
					oppssetlist = List[Profile.OffsetProfileParametersStation](oppsset)
					opp.Stations = oppssetlist
					#a = opp.Stations
					t.Commit()
	except Exception() as ex:
		oppstations.append(ex.message)
	return oppstations
# Assign your output to the OUT variable.
OUT = offsetsuper(align,station,slope)
serpetfree
Thanks for your help, problem solved.
