Créate Cicle y Line
Créate Cicle y Line
bschristhian
Créate Cicle y Line
bschristhian
Hello, how are you? The truth is that I am quite new to using VB.NET, what I want to do is:
First click on Create Circle
Second Click on the polyline is created and the first circuit is deleted and the second one is created
And all of it take it to a loop
I attach an image of what I have and what I want
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.Interop
Imports Autodesk.AutoCAD.Interop.Common
Imports System.Windows.Forms
Public Class Form1
    Dim vDocument As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
    Dim vDatabasa As Database = vDocument.Database
    Dim vEditor As Editor = vDocument.Editor
    Dim vBlockTable As BlockTable
    Dim vBlockTableRec As BlockTableRecord
    Private Sub Button2_Click(sender As Object, e As EventArgs) Handles Button2.Click
        Me.Finalize()
    End Sub
    Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
        Me.Hide()
        Dim pPtoOpciones As PromptPointOptions = New PromptPointOptions("")
        Dim pPtoResultado As PromptPointResult
        pPtoOpciones.Message = vbLf & "Ingrese primer Punto: "
        pPtoResultado = vEditor.GetPoint(pPtoOpciones)
        Dim Pto1 As Point3d = pPtoResultado.Value
        If pPtoResultado.Status = PromptStatus.Cancel Then
            Me.Show()
            Exit Sub
        pPtoOpciones.UseBasePoint = True
        pPtoOpciones.BasePoint = Pto1
        pPtoOpciones.Message = vbLf & "Ingrese Segundo Punto: "
        Dim Pto2 As Point3d = pPtoResultado.Value
            Me.Show()
            Exit Sub
        Dim x1 As Double : Dim y1 As Double : Dim z1 As Double
        Dim x2 As Double : Dim y2 As Double : Dim z2 As Double
        x1 = Pto1(0) : y1 = Pto1(1) : z1 = Pto1(2)
        x2 = Pto2(0) : y2 = Pto2(1) : z2 = Pto2(2)
        Me.Show()
        Using lock As DocumentLock = vDocument.LockDocument
            Dim acDoc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim acCurDb As Database = acDoc.Database
            Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                Dim acBlkTbl As BlockTable
                acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
                Dim acBlkTblRec As BlockTableRecord
                acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace),
                                            OpenMode.ForWrite)
                Dim acCirc As Circle = New Circle()
                acCirc.SetDatabaseDefaults()
                acCirc.Center = New Point3d(Pto1(0), Pto1(1), Pto1(2))
                acCirc.Radius = Val(TxtRadius.Text)
                acBlkTblRec.AppendEntity(acCirc)
                acTrans.AddNewlyCreatedDBObject(acCirc, True)
                acTrans.Commit()
            End Using
        End Using
            Using vtransaction As Transaction = vDatabasa.TransactionManager.StartTransaction
                vBlockTable = vtransaction.GetObject(vDatabasa.BlockTableId, OpenMode.ForRead)
                vBlockTableRec = vtransaction.GetObject(vBlockTable(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
                Dim vlinea As Line = New Line(Pto1, Pto2)
                vlinea.SetDatabaseDefaults()
                vlinea.ColorIndex = 1
                vlinea.LineWeight = LineWeight.LineWeight013
                vBlockTableRec.AppendEntity(vlinea)
                vtransaction.AddNewlyCreatedDBObject(vlinea, True)
                vtransaction.Commit()
                MsgBox(vlinea.Length)
            End Using
        End Using
    End Sub
End Class
hosneyalaa
Hi
Can you put a question on the site?
so
If only it was related to Autocad
https://forums.autodesk.com/t5/net/bd-p/152
bschristhian
thank you I posted it in the correct area
