LabelStyleTextComponent not updated in the UI
soonhui
Advisor Advisor
soonhui
I'm pretty sure this is a bug in Civil 3D: I found that when I update the content value in LabelStyleTextComponent , the UI is not immediately updated as it should.
You can use the attached drawing, and the following code to test.
    [CommandMethod(nameof(ProfileBandStyleReadOnly))]
    public static void ProfileBandStyleReadOnly()
        Document aDoc = Application.DocumentManager.MdiActiveDocument;
        Editor ed = aDoc.Editor;
        Database db = aDoc.Database;
        using var tr = db.TransactionManager.StartTransaction();
        var profileDataId = CivilApplication.ActiveDocument.Styles.BandStyles.ProfileViewProfileDataBandStyles["Vertical Elevations and Stations"];
        var profileData = tr.GetObject(profileDataId, OpenMode.ForWrite) as ProfileDataBandStyle;
        var titleText = tr.GetObject(profileData.TitleTextLabelStyleId, OpenMode.ForWrite) as LabelStyle;
        var allComponents = titleText.GetComponents(LabelStyleComponentType.Text);
        var res = tr.GetObject(allComponents[0], OpenMode.ForWrite) as LabelStyleTextComponent;
        var theText = res.Text;
        var theHeight = theText.Height;
        var theContent = theText.Contents;
        theContent.Value = @"station\PABC (m) \PDEC";
        tr.Commit();
To update it, you will have to click Apply on the Label Style Composer, as shown below, then it will be automatically updated.
Note, similar cases:
  1. https://forums.autodesk.com/t5/civil-3d-customization-forum/some-contentstringformatted-doesn-t-upda...
  2. https://forums.autodesk.com/t5/civil-3d-customization-forum/edit-the-text-component-editor-value-via...
Ngu Soon Hui
I'm the Benevolent Dictator for Life for MiTS Software. Read more here
I also setup Civil WHIZ in order to share what I learnt about Civil 3D
michal_hcz
hi,
Autodesk.AutoCAD.Internal.Utils.FlushGraphics(); did not help but ed.Regen(); works fine. Not the best solution but at least somenting 🙂
M.
soonhui
@michal_hcz , are you sure that you can reproduce the problem?
Because just now I ran the code as it is, suddenly the problem is no longer reproducible.
Similar problems in other linked post are, however, still reproducible.
Ngu Soon Hui
michal_hcz
Yes, the prohlem is still here.
Latest C3D 2026, your DWG.
After your command:
After ec.Regen():
M.
