How to get surface boundary when imported from LandXML using .NET API
vucic_tamara
vucic_tamara
I have few surfaces in the drawing that are imported from LandXML format. Now I need to write a piece of code in C# that iterates through surfaces and then gets surface borders to do some calculations on them. But the problem is that whatever method I seem to use I get no borders from them. This is what I tried so far:
var boundariesDef = surface.BoundariesDefinition;
var borderObjectIds1 = surface.ExtractBorder(SurfaceExtractionSettingsType.Plan);
var borderObjectIds2 = surface.ExtractBorder(SurfaceExtractionSettingsType.Model);
var dbcol = new DBObjectCollection();
surface.Explode(dbcol);
And all of the collections are empty.
If anyone can give any hint on what to do to get the borders it would be great!
Thank you,
Tamara
Jeff_M
Can you share the dwg and testable code? I just ran a quick test here and the border extracts as expected.
vucic_tamara
Hi Jeff,
When I prepared a test drawing and extracted sample code as you asked I ran my sample code and everything turned out to work perfect.  All of the methods stated above were returning boundary objects.
Then I started to compare what was different between my original code and the one I prepared as a sample to send you.
I noticed one thing different - I was calling my methods in original code from UI thread, and in my sample code I was calling it via CommandMethod.
And the important thing I noticed is that I didn't wrap my Civil related code in DocumentLock using statement when calling from UI thread.
After I wrapped my code like this everything seems to be working right:
var doc = ACApplication.DocumentManager.MdiActiveDocument;
using(var dockLock = doc.LockDocument())
//Do my surface calculations
Now it is working so I hope this was the problem. Thank you very much, if you weren't asking for example I would have never figured it.
Greetings,
Tamara
Jeff_M
Glad I was able to help in some way! Thanks for posting your findings.
