- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have few surfaces in the drawing that are imported from LandXML format. Now I need to write a piece of code in C# that iterates through surfaces and then gets surface borders to do some calculations on them. But the problem is that whatever method I seem to use I get no borders from them. This is what I tried so far:
var boundariesDef = surface.BoundariesDefinition;
var borderObjectIds1 = surface.ExtractBorder(SurfaceExtractionSettingsType.Plan);
var borderObjectIds2 = surface.ExtractBorder(SurfaceExtractionSettingsType.Model);
var dbcol = new DBObjectCollection();
surface.Explode(dbcol);
And all of the collections are empty.
If anyone can give any hint on what to do to get the borders it would be great!
Thank you,
Tamara
