How to create feature lines from objects (alignments) using the C# API
daniel_rosell_moreno
Message 1 of 9
Good morning, I've been trying to do this for a while now but I haven't been able to do it.
The idea is that given a list of alignments, convert each of them into a dynamic feature line.
From the interface it is very easy, in home, click "Feature line">"Create Feature Lines from Alignment".
I look forward to your responses and thanks in advance.
Replies (8)
Message 2 of 9
hosneyalaa
@daniel_rosell_moreno
HI ... TRY
1-GET Polyline FROM Alignment WITH   GetPolyline
2- Creates a FeatureLine from the Polyline WITH  Create(String, ObjectId)
3- Set an elevation to existing Feature Point FROM profile  WITH        SetPointElevation
4- Inserts a PI point along the FeatureLine FROM  (profile entities  WITH   Entities  ) WITH InsertPIPoint
Message 3 of 9
Sorry, I don't explain myself well.
What I have is an alignment, with several profiles.
What I want is to make a characteristic line using one of the profiles of said alignment.
Mention that it is very important that the new characteristic line is dynamic.
Anyway thanks for your answer.
Message 4 of 9
hosneyalaa
Hi
Can you attached example drawing and explain your idea
I am understanding you correctly
Message 5 of 9
I have this alignment:
And the steps I follow to create the characteristic line are the following:
Message 6 of 9
hosneyalaa
Try  @daniel_rosell_moreno
Get ngl profile
Change this line
(prof.ProfileType == ProfileType.FG)
Here's one way ... code by @Jeff_M @
// https://forums.autodesk.com/t5/civil-3d-customization/get-the-design-profile/m-p/10080874
public ObjectId GetDesignProfile(Alignment align)
            var retval = ObjectId.Null;
            foreach(ObjectId id in align.GetProfileIds())
                var prof = (Profile)id.Open(OpenMode.ForRead);
                if (prof.ProfileType == ProfileType.FG)
                    retval = id;
                prof.Close();
                if (retval != ObjectId.Null)
                    break;
            return retval;
Message 7 of 9
Ok thanks, I already have the profile with which I want to make the characteristic line. But my doubt is how to create the feature line
Message 8 of 9
hosneyalaa
what do you mean b characteristic line
I didn't understand you .
You better share some of the code
Message 9 of 9
I meant feature line not characteristic line
