Help with an error trap.
tcorey
Mentor Mentor
tcorey
My goal is to find a way to differentiate whether a parcel loop item is a line or an arc.
If I dump the object, I get either IAeccParcelSegmentCurve or IAeccParcelSegmentLine. I can't find a way to get that value into a variable.
So, I thought it would be simple. If the object is a curve, it has a radius. I ask the object (setq rad (vlax-get seg 'Radius))
That works fine when the object is a curve. If it's a line, it gives an error, which I expect it to do. What I would like to do is (setq rad nil) if the original setq rad throws an error.
I am struggling.
Thanks in advance.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Jeff_M
Tim, check if the property is available like so:
(vlax-for loop loops
  (vlax-for segment loop
    (if (vlax-property-available-p segment 'radius)
      (princ "\nSegment is an arc.") ;;do what you want with the arc segment here
      (princ "\nSegment is a line.")  ;;do what you want with the line segment here
In a short test of a Parcel with 4 lines and an arc, this is the result:
Segment is a line.
Segment is a line.
Segment is a line.
Segment is an arc.
Segment is a line.
tcorey
Thanks, Jeff!
Tim Corey
Redding, CA
