Turn off tangency warning alerts using .net
f.rampf
f.rampf
I was wondering if it is possible creating a new alignment using .net API and then disable the tangency warning alters to be displayed.
In https://forums.autodesk.com/t5/autocad-civil-3d-forum/warning-alert-for-alignments/td-p/3330537 it is explained how this is done within the Civil 3D environment but I want to do it automatically within my code.
Is that possible?
Kind regards,
Felix
Jeff_M
It does not appear that this property is exposed in the API.
Jeff_M, also a frequent Swamper
f.rampf
This is really unfortunate. Thank you very much for your answer though!
Kind regards,
Felix
Jeff_M
As a workaround, you could create a style that does not display the warning symbol and assign that style to the alignment.
f.rampf
Yeah I was thinking about that, it's a bit of an effort though.
I mean in the end the alert message shows for a reason so I guess I will just leave it and let the user (inside the program) decide what to do with it.
