Custom Part Structure with custom connection point(s)
DynamicObjects
DynamicObjects
Hello Autodesk and forum,
I would like to create a custom "storage box" structure for use in a sewer network.
I would like this structure to have up to 5 connection points for pipes to be able to connect to it. ... i.e. pipes shouldn't connect to the centre-point of the structure, but instead they should connect to any of the specific 5 points on the walls of the structure.  I want to be able to control the position of these connection points using dimensions when creating the structure in the Part Builder.
Is this even possible?
If so, once having created the custom structure in Part Builder, would my custom parameters that control the position of the 5 connection points be exposed in the API so that i can process a batch of these structures.. placing each one into my drawing and setting the value of its connection point parameters?
Atkins Consultants Ltd UK
+19,000 staff (M&E, Civils, Structural, Geotechnical, Environmental and more)
DynamicObjects
This illustrates the kind of structures i would like to connect to - without connecting to the centre of the structure.
Civil3DReminders
Yes, it is possible. I'd look at using Structure Rules to achieve what you are looking for. All of the sample code ships with the product. There is some information in help and I wrote an AU class in 2007 that has some additional information in it. It can be found on the AUGI website forum.
I see I probably need to provide a name for the class. It's Supercalifragilisticexpedaldotions Sewer Design. If you say the name loud enough
you'll always sound precocious
DynamicObjects
Thanks for your reply - i have been searching on the AUGI website forum and i can't find anything that i can identify from your clues above... would you be able to post a link please?
Jeff_M
DynamicObjects
Thanks Jeff - i'll go look thru that.
