Getting PropertySetDefinition Value of an object
lumoric
lumoric
How to get an actual Value of a object's PropertySetDefinition?
I thought it is this method:
GetValue(int propertyId, Autodesk.AutoCAD.DatabaseServices.ObjectId id, Autodesk.AutoCAD.DatabaseServices.ObjectIdCollection blockRefPath)
but it is causing Civil3d to crash with fatal error "unhandled access violation reading 0x0000 exception at autocad"
Here is my code so far:
        [CommandMethod("PropSets")]
        public void PropSets()
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            CivilDocument doc = CivilApplication.ActiveDocument;
            // select a  TIN surface
            PromptEntityOptions opSelSurface = new PromptEntityOptions("\nSelect a TIN Surface: ");
            opSelSurface.SetRejectMessage("\nOnly TIN Surface is allowed");
            opSelSurface.AddAllowedClass(typeof(TinSurface), true);
            opSelSurface.AppendKeywordsToMessage = true;
            PromptEntityResult resSelSurface = ed.GetEntity(opSelSurface);
            ObjectId surfaceId = resSelSurface.ObjectId;
            Database db = Application.DocumentManager.MdiActiveDocument.Database;
            using (Transaction transsrc=db.TransactionManager.StartTransaction())
                TinSurface surface = transSrc.GetObject(surfaceId, OpenMode.ForWrite) as TinSurface;
                ObjectIdCollection plinePropSetDefs = PropertyDataServices.GetPropertySetDefinitionsUsed(surface);
                foreach (ObjectId plinePropSetDef in plinePropSetDefs)
                    var prop = transSrc.GetObject(plinePropSetDef, OpenMode.ForWrite) as PropertySetDefinition;
                    foreach(PropertyDefinition propDef in prop.Definitions)
                        ObjectIdCollection idsDummy = new ObjectIdCollection();
                        string val = propDef.Description;
                        try
                            string propsetdef = prop.GetValue(propDef.Id, surfaceId, plinePropSetDefs).ToString();
                            Application.ShowAlertDialog("Surface property set def: " + propDef.Name.ToString() + propsetdef);
                        catch (Exception ex)
                            Application.ShowAlertDialog(ex.Message);
hosneyalaa
HI @lumoric
Because he gives a  NULL  when he REEGING OBJECTID
 as in Image
TRY :
 [CommandMethod("TESTPropSets")]
                TinSurface surface = transsrc.GetObject(surfaceId, OpenMode.ForWrite) as TinSurface;
                    var prop = transsrc.GetObject(plinePropSetDef, OpenMode.ForWrite) as PropertySetDefinition;
                    foreach (PropertyDefinition propDef in prop.Definitions)
                        try
                            var propsetdef = prop.GetValue(propDef.Id, surfaceId, plinePropSetDefs);
                            //Application.ShowAlertDialog("Surface property set def: " + propDef.Name.ToString());
                        catch (System.Exception ex)
hippe013
The following is an example as to how to get the value of the PropertySet
Dim propSetId As ObjectId = PropertyDataServices.GetPropertySet(dbObject, _propertySetDefinitionId)
Dim propSet As PropertySet = tr.GetObject(propSetId, OpenMode.ForRead)
Dim val As Object = propSet.GetAt(propSet.PropertyNameToId(propertyName))
I hope that this helps!
james_fisher1
Just verifying that this can only be done by python?
hippe013
The OP is writing in C# on the .NET framework. In Hosneyalaa's post they are using Dynamo. And in my example I am writing in VB on the .NET framework. Are you referring to using Python in Dynamo?
james_fisher1
Sorry, I meant to ask if it requires code to be written, or if it can be done with modules?
hippe013
I guess I am not sure what you mean when you say modules. In terms of VB a module is a Static Class, as in a module cannot create instances on an object. I am assuming you are referring to using Python? The code posted in this thread is for creating a DLL file that can be imported through the use of the NETLOAD command. Feel free to start a new thread with your question about Modules and the use of Python. That will help engage others in answering your question.
