Parcel Loops alternative in .NET API
a.mergu
a.mergu
I'm new to CIVIL 3D customization, but I have a fair experience in programming. I'm trying to reference the parcel segments that were used to create a Parcel in my .NET code, but in vain. On further searching, I found out that there's something called a Parcel Loop in the older COM API.
COM API Reference - Link
Is there an alternative to the parcel loop in new .NET API? If there isn't one, can someone please share any other resources which can help me explore ways to retreive parcel data?
Thanks.
a.mergu
Thank you @hosneyalaa . This worked! I didn't know we could use COM objects inside the .NET API. I'm still having a trouble figuring out the closest points to the parcel segments, but I hope I'll get there. Thanks a ton for the info !
hosneyalaa
Hi @a.mergu
my language is not good
 Can you put some code?
And I'm trying to help you
a.mergu
Hi @hosneyalaa ! You already gave me the answer. Thank you! I'll create a separate post if needed for other issues I'm facing.
