Get error message when try to run code aeccDoc.Surfaces (aeccDoc = AeccDocument)
handgth
Message 1 of 8
handgth
Hi everyone,
I'm trying to create tin surface from LandXml file by using IAeccSurfaces Interface.
(https://adndevblog.typepad.com/infrastructure/2012/12/creating-a-tin-surface-from-landxml-file.html)
But I got the error message in row  "Autodesk.AECC.Interop.Land.AeccSurfaces oAeccSurfaces = aeccDoc.Surfaces;"
How can I fix this problem?
Or Is there any other way I can create TinSurface from file LandXml ?
Thanks everyone.
Replies (7)
Message 2 of 8
Todd_Rogers
See if @Civil3DReminders_com can help out...
Todd Rogers
Civil Administration at Walter P Moore
Message 3 of 8
Jeff_M
Which release of Civil 3D are you coding for? Do you really need to be using the COM API? There is now a .NET API method to create a TinSurface from a LandXML file.
Message 4 of 8
You have to change this line:
string sAppName = "AeccXUiLand.AeccApplication.10.0"; // Civil 3D 2013
to match the version of Civil 3D you are using.
I'd suggest using the method Jeff shows here to never have to use the string again:
https://forums.autodesk.com/t5/civil-3d-customization/aeccxuiland-aeccapplication/m-p/8775700/highli...
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Message 5 of 8
handgth
I'm working with Civil3d 2020 and Civil3d 2021.
No, I don't. I can not find that method in .NET API ... so I have to use the method in COM API.
Could you please send me the .NET API method to create a TinSurface from a LandXML file?
Thank you.
Message 6 of 8
hosneyalaa
This. method to create a TinSurface from a LandXML file?
https://help.autodesk.com/view/CIV3D/2022/ENU/?guid=e3344531-c49f-503d-1a47-d26ff98faf21
Message 7 of 8
handgth
Thank you
Message 8 of 8
handgth
Thank you.
