Code generated tables not visible in AutoCAD on giving the Insertion Point
priya.mishraTPDMG
priya.mishraTPDMG
Hi All,
I am creating 15 tables with the help of the below code. I am passing a 2d string array for every table. The 2d arrays are getting created and passed correctly. There's a prompt for the user to select the insertion point of the table for each table. When I run the code, the user is asked to enter the insertion point 15 times i.e. for each table, but there's no table created in the model space.
Any help would be appreciated. @norman.yuan  @Jeff_M
public static void CreateTable(string[,] str)
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
PromptPointResult pr = ed.GetPoint("\nEnter table insertion point: ");
if (pr.Status == PromptStatus.OK)
Autodesk.AutoCAD.DatabaseServices.Table tb = new Autodesk.AutoCAD.DatabaseServices.Table();
tb.TableStyle = db.Tablestyle;
tb.SetSize(str.GetLength(0), str.GetLength(1));
tb.SetRowHeight(50);
tb.SetColumnWidth(130);
tb.Position = pr.Value;
// Use a nested loop to add and format each cell
for (int i = 0; i < tb.Rows.Count; i++)
for (int j = 0; j < tb.Columns.Count; j++)
string item = str[i, j];
tb.Cells[i, j].TextHeight = 10;
tb.Cells[i, j].TextString = item;
tb.Cells[i, j].Alignment = CellAlignment.MiddleCenter;
tb.GenerateLayout();
using (Transaction tr = db.TransactionManager.StartTransaction())
BlockTable bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
btr.AppendEntity(tb);
tr.AddNewlyCreatedDBObject(tb, true);
tr.Commit();
Thankyou in advance.
Priya Mishra
Jeff_M
Your code works to add a single table. Does the calling function have an uncommitted Transaction?
Jeff_M, also a frequent Swamper
priya.mishraTPDMG
Thankyou @Jeff_M You were right. The calling function had an uncommitted Transaction. Now its working perfectly!
@Jeff_M @norman.yuan
Can you please help me in knowing how to generate a table of the following format through code:
I tried the tb.UnmergeCells() and tb.MergeCells() but could not get the desired results.
Thanks in advance.
-Regards
Priya Mishra
Jeff_M
Something like this?
        [CommandMethod("TableTest")]
        public static void CreateTable()
                tb.SetSize(8,13);
                tb.SetColumnWidth(80);
                var r1 = CellRange.Create(tb, 1, 1, 1, 12);
                var r2 = CellRange.Create(tb, 2, 1, 2, 12);
                var r3 = CellRange.Create(tb, 2, 0, 7, 0);
                tb.MergeCells(r1);
                tb.MergeCells(r2);
                tb.MergeCells(r3);
                    tr.Commit();
priya.mishraTPDMG
Thankyou so much @Jeff_M
This is exactly what I asked for! Thanks again for the help!
