Modify lsp to be used for all versions
mikemcculley5692
mikemcculley5692
I have a lsp routine that was created by Jeff Mishler and modified by Ian McClain that I need to be able to use on C3D 2021 and above. I have no clue how to modify it to accept all versions.
Mike McCulley
;|Command to globally change the MarkerDisplay and MarkerLabel color to BYLAYER
to be used for all point styles.
Created 8/4/2014 by Jeff Mishler of Quux Software
Modified 6/5/2018 by Ian McClain of Stantec Consulting
(defun c:PointLabelsBylayer
(/ *acad* c3d c3ddoc enum prod prodstr siztyp)
(vl-load-com)
(setq prod (vlax-product-key))
(setq prodStr (strcat "AeccXUiLand.AeccApplication"
(cond ((vl-string-search "\\R17.0\\" prod)
".4.0"
;;2007
((vl-string-search "\\R17.1\\" prod)
".5.0"
;;2008
((vl-string-search "\\R17.2\\" prod)
".6.0"
;;2009
((vl-string-search "\\R18.0\\" prod)
".7.0"
;;2010
((vl-string-search "\\R18.1\\" prod)
".8.0"
;;2011
((vl-string-search "\\R18.2\\" prod)
".9.0"
;;2012
((vl-string-search "\\R19.0\\" prod)
".10.0"
;;2013
((vl-string-search "\\R19.1\\" prod)
".10.3"
;;2014
((vl-string-search "\\R20.0\\" prod)
".10.4"
;;2015
(t "")
(and (setq *acad* (vlax-get-acad-object))
(setq C3D (vla-getinterfaceobject *acad* prodStr))
(setq C3Ddoc (vla-get-activedocument C3D))
(progn
(vlax-for styl (vlax-get c3ddoc 'PointStyles)
(vlax-put-property (vlax-get styl 'markerdisplaystyleplan) 'color "BYLAYER")
(vlax-put-property (vlax-get styl 'labeldisplaystyleplan) 'color "BYLAYER")
(vlax-put-property (vlax-get styl 'markerdisplaystylemodel) 'color "BYLAYER")
(vlax-put-property (vlax-get styl 'labeldisplaystylemodel) 'color "BYLAYER")
(vlax-put-property (vlax-get styl 'markerdisplaystyleprofile) 'color "BYLAYER")
(vlax-put-property (vlax-get styl 'markerdisplaystylesection) 'color "BYLAYER")
(princ "\nAll point styles updated!")
(princ)
Jeff_M
Replace this:
".4.0"
;;2007
".5.0"
;;2008
".6.0"
;;2009
".7.0"
;;2010
".8.0"
;;2011
".9.0"
;;2012
".10.0"
;;2013
".10.3"
;;2014
".10.4"
;;2015
(t "")
with this:
  (defun getaeccApp (module / *acad* C3D) ;; module must be "Land", "Pipe", "Roadway", or "Survey"
  (vl-load-com)
  (if (and (setq *acad* (vlax-get-acad-object))
	   (setq C3D (strcat "HKEY_LOCAL_MACHINE\\"
			     (if vlax-user-product-key
			       (vlax-user-product-key)
			       (vlax-product-key)
		 C3D (vl-registry-read C3D "Release")
		 C3D (substr
		       C3D
		       1
		       (vl-string-search
			 C3D
			 (+ (vl-string-search "." C3D) 1)
		       (strcat "AeccXUi" module ".Aecc" (if (= (strcase module) "LAND") "" module) "Application." C3D)
    C3D
     (setq c3d (getaeccapp "Land"))
And it will work until Autodesk decides to change something that hasn't changed in 10+ years.
Jeff_M, also a frequent Swamper
mikemcculley5692
Jeff, Thanks for the help. I replaced the text you specified, but when I run it I get this
#<VLA-OBJECT IAeccDocument 00000249a91e8de0>
Jeff_M
There was an extra parenthesis. Also, "BYLAYER" didn't work, I changed those to 256 which is Bylayer.
  (vl-load-com)
    (vl-load-com)
				 (vlax-product-key)
		   C3D (substr
			 C3D
			 1
			 (vl-string-search
			   C3D
			 (strcat "AeccXUi"
				 module
				 ".Aecc"
				   module
				 "Application."
				 C3D
      C3D
    (vlax-put-property
      'color
      256
    (vlax-put-property
      'color
      256
    (vlax-put-property
      'color
      256
    (vlax-put-property
      'color
      256
    (vlax-put-property
      'color
      256
    (vlax-put-property
      'color
      256
  (princ)
mikemcculley5692
Thanks Jeff_M! Quick question. If I wanted to change to BYBLOCK, what would I need to change 256 to?
Jeff_M
ByBlock = 0
