About Alignment Curve Return ...
flycoflyco
flycoflyco
Hello~ I want to create Alignment Curve Return using .net(Vb/C#)
But, there is nothing about Alignment Curve Return method
Also, there is nothing about intersection.create()
I want to know how to make the intersection road.
I appreciate you taking the time
joantopo
I think that "Alignment Curve Return" is just a type of alignment, not an object.
Actually, is the same that any another Aligment.
Alignment Class has the property Type, when you can choose what type do you want.
One of this types is just "Alignment Curve Return".
You can Read/write this property.
Then, according to the choosen type, the alignment will appear in the ToolSpace, within the Alignment category, in the specific type folder.
By default, when you create an automatic Intersection or Roundabout, all involved new alignments will have this type.
I think that it just serves to differ the alignments in several folders in the ToolSpace.
Autocad C3D 2019 SP3, 2020 & 2021
Intel I9 9900K with frontal watercooler alphacool eisbaer 360 (original fans mounted in pull)- 3 fans Corsair 120 ML PRO in push.
MOBO Gygabyte Z390 Aorus Master- Corsair RGB Vengeance 64GB RAM (4x16) CL16
Nvidia Quadro RTX 4000
Samsung 970 EVO PLUS 1TB (unit C). Samsung 970 PRO 512GB (for data)
Power Supply: Corsair TX850M PLUS
Descubre mi programa VisorNET para Civil 3D:
https://apps.autodesk.com/CIV3D/es/Detail/Index?id=appstore.exchange.autodesk.com%3avisornet_windows32and64%3aes
flycoflyco
Thangk you for your reply!
Because Alingment Type can not changed,I make it normal type Alignment (Centerline)
