Hello everyone,
I am searching for Quality in results but unable to find it. but this is very important criteria to judge or analyse the situation. can anyone please tell me where can I find this Quality.
Suppose I want to see the quality of the fluid at outlet then which tool I should use to find that?
thanks in advance,
regards,
Akshay Kumar
Hello everyone,
thanks in advance,
regards,
Akshay Kumar
Solved by Jon.Wilde. Go to Solution.
Hi @Anonymous,
Thank you for your Post in the Forum.
I´m glad that Jon Wilde could answer your question.
Thank you,
Hi @Anonymous,
Thank you,
Hi @Mike.Grau
thank you for your response!
the fluid is entering with hot temp. with quality[1], but if I want to see what is the quality of fluid at outlet then how can I see that?
I have attached my file.
regards,
Akshay Kumar
Hi @Mike.Grau
regards,
Akshay Kumar
Hi Akshay,
You only need to plot the 'Scalar' at the outlet to obtain the Steam Quality, should be quite simple 🙂
I would do it with a cut-plane and the bulk calculator for a value right across the outlet.
Shout if you need any guidance doing so.
Check out the attached file as one that is set up properly, might be of use! (Yup, you will see that it is quite old...).
Hope that helps,
Jon
Hi Akshay,
Hope that helps,
Jon
Thank you Sir! Now I got the use of that scalar option.
regards,
Akshay Kumar
regards,
Akshay Kumar
