CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Simualtion stopped due to the divergence
7 REPLIES 7
Message 1 of 8
1163 Views, 7 Replies
Hello, When doing a wind study for an urban case study, the simulation stopped due to the divergence. I tried several times by changing the settings, e.g. reducing the mesh size, editing CAD geometry to make it simpler, but still facing this problem. Any hint how I can overcome this? It stopped after 250 iterations. I usually set the number of iteration 750, based on guidelines for the wind simulation in Autodesk CFD. Regards, Saeed E
7 REPLIES 7
Message 2 of 8
Jon.Wilde
Jon.Wilde
What happens with just an auto mesh? Typically coarsening the mesh is not so wise (more likely to diverge).
Could you share a little detail about the Boundary Conditions (BC) you are using and perhaps a screenshot also? Is there plenty of clear air downstream?
Jon
Jon
Message 3 of 8
in reply to: Jon.Wilde
Hi Jon, Thanks for following up my question. I got the message with both when running with only with auto-mesh and when using a fine mesh region. Boundary box dimensions are approximately 5W, 6L and 5 Hmax. I have 3 times of the model length in the down stream area. I enclosed a screen shot. Regards, Saeed
Message 4 of 8
The screen shot
The screen shot
Message 5 of 8
Jon.Wilde
Jon.Wilde
Either your model is all in white or that upload failed. Might you be able to try again? 🙂
The dimensions do sound OK though - feel free to share a support file (CFZ) also.
Thanks!
Jon
Thanks!
Jon
Message 6 of 8
I suspected that I wasn't successful with attaching my file. Now I try for the third time to attach files. This time with the support file.
Regards!
Saeed
Regards!
Saeed
Message 7 of 8
Jon.Wilde
Jon.Wilde
Got it, thanks.
Firstly, the setup looks great - my guess is that the mesh is too coarse. A few thoughts:
We need a minimum of 5-8 elements from top to bottom, here there is just one:
Suppress the buildings:
Try meshing with 3 Gap Elements to better capture the flow between buildings:
Mesh refined to give more elements at the edges:
Don't forget to press 'Refine' to implement the Surface and Gap Refinment before solving.
Use Advection Scheme 5 (Solve -> Solution Controls -> Advection)
The meshing failed at surface 6 - I think it might be worth checking your CAD is clean:
A manual mesh might be a nice quick approach here though. Something like 35m on the air volume and 2m on the building surfaces as a first guess.
It does mean Surface and Gap Refinement have no effect but it also works...
Hope that helps, have a nice weekend 🙂
Jon
Got it, thanks.
Jon
Message 8 of 8
Thanks Jon, Sorry for late reflection on your answer. It helped a lot and I could finish the simulation. Kind regards, Saeed
