Solved by Jon.Wilde. Go to Solution.
What happens with just an auto mesh? Typically coarsening the mesh is not so wise (more likely to diverge).
Could you share a little detail about the Boundary Conditions (BC) you are using and perhaps a screenshot also? Is there plenty of clear air downstream?
Jon
Either your model is all in white or that upload failed. Might you be able to try again? 🙂
The dimensions do sound OK though - feel free to share a support file (CFZ) also.
Thanks!
Jon
I suspected that I wasn't successful with attaching my file. Now I try for the third time to attach files. This time with the support file.
Regards!
Saeed
Got it, thanks.
Firstly, the setup looks great - my guess is that the mesh is too coarse. A few thoughts:
We need a minimum of 5-8 elements from top to bottom, here there is just one:
Suppress the buildings:
Try meshing with 3 Gap Elements to better capture the flow between buildings:
Mesh refined to give more elements at the edges:
Don't forget to press 'Refine' to implement the Surface and Gap Refinment before solving.
Use Advection Scheme 5 (Solve -> Solution Controls -> Advection)
The meshing failed at surface 6 - I think it might be worth checking your CAD is clean:
A manual mesh might be a nice quick approach here though. Something like 35m on the air volume and 2m on the building surfaces as a first guess.
It does mean Surface and Gap Refinement have no effect but it also works...
Hope that helps, have a nice weekend 🙂
Jon
