Hey,
I am designing room with radiant panels in it. When I import to cfd, not able to select the geometry. Am I missing anything while creating geometry? how to design airtight model? and facing a problem with assigning materials.
Solved by Jon.Wilde. Go to Solution.
How do you mean, you cannot select the geometry?
Could you share a Screencast to help explain?
If you wish CFD to build the internal air for you, be sure that all walls are touching and that everything is closed.
What CAD are you working from?
Jon
Great! So everything is good now?
Jon
I want to Input Polypropylene material in CFD. Can you please guide how can I edit Propylene in material list ?
