CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Radiant Cooling cieling system
6 REPLIES 6
465 Views, 6 Replies
Hey,
I am designing room with radiant panels in it. When I import to cfd, not able to select the geometry. Am I missing anything while creating geometry? how to design airtight model?  and facing a problem with assigning materials.
6 REPLIES 6
Jon.Wilde
How do you mean, you cannot select the geometry?
Could you share a Screencast to help explain?
If you wish CFD to build the internal air for you, be sure that all walls are touching and that everything is closed.
What CAD are you working from?
Jon
in reply to: Jon.Wilde
I found the solution. My geometry was not air tight.
Jon.Wilde
Great! So everything is good now?
Jon
I want to Input Polypropylene material in CFD. Can you please guide how can I edit Propylene in material list ?
Jon.Wilde
Could I ask you to start a new thread for others to follow? Edit an existing material, input the PP data and save it with a new name into your own database (My Materials). Is that all you need to know? Thanks, Jon
thanks . Gonna do it . I will create new thread.
