Problem with assembly model
Is there any Solutions of problem with transfer model form Inventor 2008 (*.iam) to CFD Simulation?
When i do this, CFD show me that "Check model surface diagnostics. Meshing failure may result with default autosize settings." and i don't heave idea what to do.
Jon.Wilde
Did you try checking the surface diagnostics as the message suggested? I would think there are some really tiny surfaces, or impossible overlaps somewhere in the model?
Saving out a sat file and importing that into CFD might fix it, if the issue is minor 🙂
Jon
Jon.Wilde
When you looked into the Surface Diagnostics, did you see any that looked really small?
I would look for ones that appear to be more of an edge/line than a surface - these will be an issue.
Amal.C
Hi @Anonymous,
I would like to check if importing the geometry as sat file helped resolve the issue.
Please let us know if you still need assistance.
Amal
Amal Cheikh rouhou
