CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
I cant find my results in saved simulations
5 REPLIES 5
549 Views, 5 Replies
I am relatively new to Autodesk CFD and one thing I noticed is that each time I save a simulation with solved results, on opening the cfdst file again, the results are cleared and I am forced to rerun the analysis. Is this normal? From my experience with other FEA software like Nastran-in-CAD and Simulation Mechanical, saved simulation results are always there even when changes are made to the model and current results are invalid.
What am I doing wrong?
5 REPLIES 5
matt.bemis
Hi @Anonymous,
This is definitely not normal 🙂 Is the working directory on your local C drive? Not a network drive? Make sure you're not working from a folder that is being synced with a Box folder or something similar.
Check the solver folder of a project which has/should have results. Are there .res files in it? These are the results files.
Matt Bemis
Technical Support Specialist
in reply to: matt.bemis
Project folder in is local drive (no cloud syncing). I checked the result folder and I couldn't see any .res file.
Can you look at this and let me know what exactly I'm doing wrong: https://drive.google.com/open?id=0B1Gh0qbGN7nedFVHcVpJMmY0eG8
matt.bemis
@Anonymous,
Thanks for the info. Can you please check the google drive link you used? I am getting an error when I try it.
Matt Bemis
Hello Matt,
Thank you but I have figured out the issue myself.
matt.bemis
@Anonymous,
Awesome news! Best of luck modeling!
Matt Bemis
