How to use Distributed Resistances function
Hello
I would like to use the Distributed Resistances function of the CFD to implement the filter.
Can the filter function be implemented with the free area ratio function?
Or is there another way?
And I created and tested Distributed Resistance Models in the Verification category.
I wonder how to judge this result.
So I'm wondering how the Distributed Resistances feature works well as a filter.
Thank you.
benoit.neu-faber
Hi @Anonymous
I would suggest you to have a look to the following link :
http://help.autodesk.com/view/SCDSE/2019/ENU/?guid=GUID-BCF33737-497B-47B8-867B-5DF174A7F9D1
Hope this help.
Benoit Neu-Faber
Autodesk Service Provider
https://www.linkedin.com/in/benoit-neu-faber/
Please accept solution and give likes if applicable
Hello benoit.neu-faber
Thanks for the answer.
What I wondered about is checking whether the Distributed Resistances feature works.
I set up the Distributed Resistances function in the middle, input the velocity in the inlet, and the pressure in the outlet, and calculate.
As a result, the outlet speed is the same as the inlet speed (steady state).
How can I verify that the Distributed Resistances function is working properly in the calculations now?
