CFD Error Message: Surface cannot be meshed
Hi, I am student who's new to CFD 2019. I am following a tutorial but I keep encountering error messages along the way. I have tried a few ways to try and fix it but I am also unsure of what exactly the problem might be. I tried autosizing, using the geometry tools, and refinement. I am not sure where to go from here and could use a step in the right direction please
This is the first error I got after only autosizing and running the solve simulation, and once again after size refining the volume:
This is the error I got after autosizing again and setting the surface and gap refinement to true but I wasn't sure how to fix this one:
Best,
Nat
I am attaching my Revit2020 file just in case since that's where I started from. It's where I got my SAT file and then imported that into CFD.
marwan_azzam
Hello Natalia,
I have one word of advice for you: simplify.
Your model has way too many details and a lot of them can cause meshing issues.
For starters, the long, seemingly extra, volums seen in image below can cause a problem.  They will probably go away after you simplify the model.
Another example is the toilet.  It has way too many details and hence volumes.  See the following 5 images.  If can probably be replaceed with a simple shape.
You have door handles, faucets and so on that may not need to be in the model.
cheers,
Marwan
