software uses Autodesk CFD 2023.
i got error message 'str' object is not callable when generate the document.
i was try to do 'run as administrator' but it's not help.
Solved by karol.suchon. Go to Solution.
Hello Akhid,
That is a known situation and was reported as a defect of the software.
There is no workaround for that issue other than using CFD 2019.
Sorry about that.
best regards,
Karol
Hello Suchon,
but sadly, i can't download 2019 version in my account.
the option it's only 2021 & 2023 Version.
In that case, you will need to contact your Autodesk Partner.
Probably you have the single-user license, and that one works only in versions 2021 and 2023.
Best regards,
Karol
Hi @karol.suchon
apart from these feature.
is there any information about others feature that not work properly rather than 2019 version?
The phase change also does not work in the newer version than 2019.
And that's all I know.
Hi Karol, any news on this issue? Nobody with a Single User Lic can access 2019. I have a customer with the same issue. 2024 in the pipeline? Cheers Alex (mum.de)
Running into the same issue.
Would be nice to hear of some anticipated fix date.
Wishing it could be an easy fix that could occur soon,....rather than waiting on an annual full CFD update which may be months away. 🙂
"Sadly, the 2024 version has already been released, but this issue remains unresolved. So, what's the point of the new version coming out?"
Hi All, any update\resolutions to solve this problem?
I also encountered same error with 2023 and 2024 version.
It seems that hotfix to Version 24.0.1 helps to this str-problem. At least when both update-installer and CFD run As Administrator I get reasonable reports out.
