CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Generate report ... 'str' object is not callable
12 REPLIES 12
Message 1 of 13
akhid.rosyidi
4280 Views, 12 Replies
akhid.rosyidi
software uses Autodesk CFD 2023.
i got error message 'str' object is not callable when generate the document.
i was try to do 'run as administrator' but it's not help.
Tags (1)
12 REPLIES 12
Message 2 of 13
karol.suchon
Hello Akhid,
That is a known situation and was reported as a defect of the software.
There is no workaround for that issue other than using CFD 2019.
Sorry about that.
best regards,
Karol
Hello Akhid,
Sorry about that.
best regards,
Karol
Message 3 of 13
akhid.rosyidi
Hello Suchon,
but sadly, i can't download 2019 version in my account.
the option it's only 2021 & 2023 Version.
Hello Suchon,
Message 4 of 13
karol.suchon
In that case, you will need to contact your Autodesk Partner.
Probably you have the single-user license, and that one works only in versions 2021 and 2023.
Best regards,
Karol
Best regards,
Karol
Message 5 of 13
akhid.rosyidi
Hi @karol.suchon
apart from these feature.
is there any information about others feature that not work properly rather than 2019 version?
Hi @karol.suchon
Message 6 of 13
karol.suchon
The phase change also does not work in the newer version than 2019.
And that's all I know.
Message 7 of 13
awouters
in reply to: karol.suchon
awouters
Hi Karol, any news on this issue? Nobody with a Single User Lic can access 2019. I have a customer with the same issue. 2024 in the pipeline? Cheers Alex (mum.de)
Message 8 of 13
chuckGED53
in reply to: akhid.rosyidi
chuckGED53
Running into the same issue.
Would be nice to hear of some anticipated fix date.
Wishing it could be an easy fix that could occur soon,....rather than waiting on an annual full CFD update which may be months away.  🙂
Message 9 of 13
akhid.rosyidi
"Sadly, the 2024 version has already been released, but this issue remains unresolved. So, what's the point of the new version coming out?"
Message 10 of 13
ARPITPATNA3
ARPITPATNA3
Yes Exactly
Yes Exactly
Message 11 of 13
gaffertSTC
gaffertSTC
Hi All, any update\resolutions to solve this problem?
I also encountered same error with 2023 and 2024 version.
Message 12 of 13
jukka_vuorinen
Observer
Observer
It seems that hotfix to Version 24.0.1 helps to this str-problem. At least when  both update-installer and CFD run As Administrator I get reasonable reports out.
Message 13 of 13
teva.marbaud
Community Visitor
Community Visitor
Hello !
Any news on this subject ?
Im on the 2024 version.
Best Regards
Hello !
Best Regards
