Fan rotor region simulation
jake
Message 1 of 16
jake
I am simulating a mixed flow fan using rotor region approach, however, the results for pressure and flow rates are not match with the test results. I followed all instructions published in Autodesk website for rotor region (Turbomachinery) CFD simulation.
Please advice me how to solve the issue?
Kind Regards,
Shaun Houreh
Replies (15)
Message 2 of 16
karol.suchon
Please attach the model and the test results.
Sometimes that is a matter of simulation time, sometimes that is a matter of postprocessing.
Your results do not have a constant value but they are changed over time, so you could pick them for comparison the pick of the pressure or volume flow rate.
BR
Karol
Message 3 of 16
jake
Hi BR Karol,
Thanks for your reply.
Please download CFD files for the fan simulation in the following link:
https://www.dropbox.com/s/6lpg1972ydb0m3j/RMC-400-600LS.zip?dl=0
CFD shows the pressure different of 200 Pa for 600l/s flow rate, but the actual one is 360 Pa.
Please help to fix it.
Kind Regards
Shaun Houreh,
Senior Mechanical Engineer
EA ID: 5147917
Message 4 of 16
karol.suchon
Hello Shaun,
I have a problem with reopening the model, could you attach the support file or create the shareable file?
BR
Karol
Message 5 of 16
jake
Hi Karol,
Please see the support file as requested.
Let me know if you need more information.
Kind Regards,
Shaun Houreh
Message 6 of 16
karol.suchon
I changed a mesh to a manual but the source of the issue is much more simple.
It is better to have a volume flow rate on the inlet and the pressure on the outlet.
After the change, I got around 360-380 Pa difference between the sides.
BR
Karol
Message 7 of 16
jake
Hi Karol,
Thanks for your support.
However, as you can see in the screenshot, the flow direction is reverse!
Flow comes from outlet to inlet. This is a fan and consumes the power to suck airflow from inlet (smaller area) to outlet (larger area).
Can you please have a look at your simulation to confirm?
Shaun
Message 8 of 16
jake
In the other word, we need to make sure it is working as a fan (absorbing power) not wind turbine (generating power).
Message 9 of 16
karol.suchon
Jake,
I do not look into the definition of VFR only to the error of direction 😞
I will try to rerun the simulation in the proper direction.
BR
Karol
Message 10 of 16
jake
Thanks.
360 Pa pressure difference is expected for 1400rpm.
For 1250 rpm, 287 Pa is ok.
inlet needs to be low pressure, outlet high pressure as this is a fan.
Shaun
Message 11 of 16
jake
Karol,
How Autodesk CFD distinguish the Fan is absorbing power or generating?
Message 12 of 16
karol.suchon
I give up on the pure free flow and create the inlet pipe.
We get some additional pressure difference generated by the decrease in the hydraulic diameter of the flow( from a big square to a small cylindrical hole).
I get around 310 Pa difference, but I think that during the time the difference could be a little smaller. The average pressure increases a little during the simulation. I will run a few more iterations and will let you know.
You could compute the power using torque in rotating region results but that is only a sign and need to be compared to the direction of the rotation.
BR
Karol
Message 13 of 16
jake
Hey Karol,
Any update on this?
Shaun
Message 14 of 16
karol.suchon
After another few rotations, the results are the same.
BTW, how does the test look in the real world, Do we have the inlet as a pipe, or it is the same as you draw?
BR
Karol
Message 15 of 16
jake
The real test has been done according to ISO 5801 – Installation type A. it means inlet chamber and outlet chamber
Fan pressure 363 @1397 rpm for 600 l/s.
Do what method CFD needs.
I can send 3D geometry of Fan too.
Message 16 of 16
karol.suchon
Ok, so I need back to the original geometry.
I will try to refine the mesh and run the simulation once again.
