Help with CFD Dust Collection flow sim
Simon.robertsX5M9D
Message 1 of 8
Simon.robertsX5M9D
Hi All
Need some help with a project am doing to check the flow (dust collection unit) has shown below.
I don’t know how to setup the CFD to show me the flow when sucking from the suction port from the main opening has shown below, my thoughts are it’s not very efficient because of the opening being so wide, so like to try narrow version too.
Have attached the IPT file
Thanks Simon
Replies (7)
Message 2 of 8
marwan_azzam
Hello Simon,
For starters, it seems your model is missing an air volume as shown below.
You can setup the model after adding that volume.
Message 3 of 8
Simon.robertsX5M9D
Hi Marwan
thanks for the reply, how do i add air volume in the model, am a newbie to CFD
Message 4 of 8
marwan_azzam
Hi Simon,
That volume cannot be generated in CFD. You need to create it in the CAD environment.
Marwan
Message 5 of 8
Simon.robertsX5M9D
Thanks marwan
Is this the correct way to create the volume? have also attached the model
Message 6 of 8
marwan_azzam
Yes, This geometry looks right.
Marwan
Message 7 of 8
Simon.robertsX5M9D
Ok thanks
next question, i have set the boundaries etc , if am using flow, suction how do i sent up the boundaries please?
just tried with pressure sent has shown below
Message 8 of 8
marwan_azzam
Hello Simon,
The way you have the BCs will not result in any flow. There is no pressure differential or anything else to drive the flow.
If you know the pressure drop you can apply that on the one end.
Otherwise you can apply a velocity or flow rate on one end and a P=0 on the other.
Marwan
