Divergence when restarting simulation
- Mute
- Permalink
- Report
I'm doing a steady state flow + thermal analysis of flow in a channel. Everything works fine with my simulation until I stop the solver to change turbulence model. In this case I stopped the solver at iteration 400 to switch from standard k-eps to RNG. When I press solve again I get divergence (I also get divergence when I try to resume the solution with standard k-eps). I've tried using both intelligent solution control and large manual under-relaxation.
The flow I'm simulating is pretty extreme and I've had some difficulties with divergence prior to this. I saw in another post that the momentum equations need to be calculated again when resuming a simulation, something which gives a "jump" to the values in the domain. Link:
Could this be the reason it diverges? Is there a way to get around this so that i can resume my simulation?
Any help is appriciated.
With kind regards
Henrik
