CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Divergence when restarting simulation
5 REPLIES 5
428 Views, 5 Replies
I'm doing a steady state flow + thermal analysis of flow in a channel. Everything works fine with my simulation until I stop the solver to change turbulence model. In this case I stopped the solver at iteration 400 to switch from standard k-eps to RNG. When I press solve again I get divergence (I also get divergence when I try to resume the solution with standard k-eps). I've tried using both intelligent solution control and large manual under-relaxation.
The flow I'm simulating is pretty extreme and I've had some difficulties with divergence prior to this. I saw in another post that the momentum equations need to be calculated again when resuming a simulation, something which gives a "jump" to the values in the domain. Link:
http://forums.autodesk.com/t5/simulation-cfd/fluctuation-of-residual-plots/m-p/3682238/highlight/tru...
 Could this be the reason it diverges? Is there a way to get around this so that i can resume my simulation?
Any help is appriciated.
With kind regards
Henrik
5 REPLIES 5
Jon.Wilde
This could be down to an issue with the setup.
Also, are you running from a local drive?
Can I ask why the choice of RNG? Are you able to share the model with us at all?
Kind regards,
Jon
in reply to: Jon.Wilde
Ok, I attach the support file.
I believe I'm running it on a local drive. I will look into this; I don't have the computer available presently.
I want to use RNG because its advantage of being more phys
Jon.Wilde
Wow, nice - a model where I do not have a single comment to make other than it is very well set up 🙂
Have you considered the SST-kw model at all? It might mean you do not need to make the switch between models.
Testing this here shows that I am able to change from one model to another but only running one iteration of each.
Jon
Hehe 😄 It is however thanks to you and some other support who gave me hints along the way 🙂
Yes, I am doing both k-w and RNG. But I am doing the initial meshstudy with RNG 🙂
Really. With the mesh I had assigned and no divergence? I am running the simulation on C: now(C: is where the program is installed, I did simulations on 😧 before)  and using RNG from start.. just to avoid having to switch models. I guess it will just take a little longer.
I read briefly in another post about running simulations on the cloud for better performance. Is this correct? because right now I need roughly ~48+ for one simulation.
Jon.Wilde
OK. I would try SST-kw too.
Sure, the cloud can be faster, it really depends on your local system. At the moment the cloud PC's are 8 core (I think they are around 2.6 GHz but I am not 100 sure).
Jon
Technology Administrators
