CFD Forum
Welcome to Autodesk’s CFD Forums. Share your knowledge, ask questions, and explore popular CFD topics.
Clarification in assigning film coefficient
3 REPLIES 3
394 Views, 3 Replies
Hello everyone,
Assigning film coefficient to the outer wall is okay.
but suppose hot fluid is moving inside the pipe then should we assign film coefficient on the outer side of fluid which is attached to internal part of pipe?
if no then why? and if yes then what should be the ref temperature. ?
please see the attachment for more clarification to my doubt.
regards,
Akshay Kumar
Hello everyone,
regards,
Akshay Kumar
3 REPLIES 3
Jon.Wilde
Jon.Wilde
We can only assign film coefficients (in fact all surface boundary conditions) on the outer boundary of the model. CFD will calculate that inner one for you based on local temps and flow speeds.
Easy peasy, one might say 😉
In your case, as you are modelling a phase change, you absolutely must model the solid outside the fluid, so there is no other option for you. Keeps things nice and simple!
Does that answer your question?
Jon
Jon
in reply to: Jon.Wilde
Thank you so much sir! Now I don't have any doubt about this. Smiley Very Happy
Jon.Wilde
Jon.Wilde
Cool, glad to help 🙂
