Below is also a list of some of the main bug fixes and solver changes:
Heath Houghton
Autodesk Fluids Simulation Product Manager
The application window seems broken in this update. It is mislocated across multiple screens at startup and when maximized to fit the screen it disappears and cannot be recovered in any known way.
I experience this on NVIDIA Quadro graphics card with driver version 431.70 on both Windows 7/10.
So I have reverted back to 2019.1.
Hi to everybody,
I did upgrade 2 days ago, and I have an annoying problem with UI:
when I change ribbon appearance (e.g. to Titles Group only) and I add some new command to Quick Access Bar and/or I move the Quick Access Bar below the Ribbon, anything works fine, till I close CFD.
At next start of CFD2019, any UI modification is lost and I need to do it again.
Thank you for your attention, Piero
p.s. any news about release CFD 2020?
Hello everyone,
I have to agree with the UI/screen problems too.
Another thing which i found is, that i can't type dot "." after any numbering whatsoever... For example for mesh refining i can't type let's say 0.7... the dot just don't appear. And of course - when i used "," instead of a "." then the effect was not applied, the mesh refining was acting like i typed a default number (meaning that no refining was done at all). In case of boundary conditions - f.e. when i wanted to set a boundary condition to a chip saying that the power is "3.5W" the dot didn't appear. When "," was used - once applied the total heat generation was set to "0W" (default number) instead of "3,5W". As a mechanical engineer who has to work with high frequency electronics, the tenths or even thousandths are a very huge dealbreaker !
If it could be resolved ASAP i would be really thankful.
Best Regards,
Miloš Tomčo
3D Mechanical engineer
I am having a similar problem. The top of the application window is off the screen when maximized. I have to change the screen resolution to see the top of the window. The top of the window will again be inaccessible if the window is maximized no matter what the screen resolution is set to.
Hi, and how you reverted CFD from 2019.2 to 2019.1, because I have the same problem
I simply did a complete uninstall of all CFD 2019.2 components and then installed 2019.1 from scratch.
i experience the same thing as @milos.tomco
the coma/dot does not work at all. When a refine region at 0.5 the software understand 5
@_@
THX
Fred
I'm experiencing the same problems as others are reporting in this thread. Is there any news on fixes coming out for CFD? The comma/dot problems and the window sizing or the window completely disappearing problems basically make this program unusable.
Can we at least get some confirmation that it's being looked into/worked on?
I experienced also severe problems importing geometry from Inventor 2020 on a completely fresh installed maschine: "This application failed to start because no Qt platform plugin could be initalized".
Besides resizing of CFD 2019.2 UI Window is complete broken.
What can solve that problem?
Made a complete reinstall to 2019.1. UI works again but now only import from Inventor 2019 is possible (of course).
Same Issue here with the Qt Plugin. What's wrong here? No reply from support either... :-(((
I also tried to contact the support via E-Mail: Nothing since almost one week now. Nobody's answering the phone there either.
The tool cannot be used altough we paid for that.
I'm very disappointed in the build quality of 2019 CFD. The issue with decimal point parameter error is still not fixed, which makes it impossible to use masses for traces. I would have expected better from a world renown company.
I had many backup simulations saved in my HDD (all with 2019.1). Now when I try to run them on 2019.2 it shows the “Analysis has stopped working...” and I found that this happens If I use a material defined by me and which has the 2nd order polymer...
This update needs a lot of attention since it brouggt more problems than solutions.
How did you find the 2019.1 version?
If I download CFD it always downloads version 2019.2. I downloaded 2019.1 update but it doesn't let me go back to that version...
Any help?
Thank you! Saved me big time.
Simply just go to Update & Add-ons and download the 2019.1 version.
